Dust behind the glass?
Hello!
I have this iMac (Retina 5K, 27-inch, 2017), and in the bottom left and right corners, I’m getting some odd blurry diagonal lines that look like some dust has been trapped between the main front glass and the display itself.
I was wondering, before I go opening the machine up, if the glass and display are separate or can be separated? If they are separate, or can be separated, then I should be able to get in there and gently wipe it off if it is indeed dust or determine if it’s not.
If they are one piece and can’t be separated, do you know any way to fix the issue? I can send pictures of the corners if you’d like.
Thank you!
Daniel
좋은 질문 입니까?
