주요 콘텐츠로 건너뛰기
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
295 질문 전체 보기
Just got iPad Air battery repair kit and can't get the screen off
tried using the iOpener, blow drier, suction cup and I can’t get the screen up. should i use the edge tool to bend the metal out a little to get under the glass?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Thanks! I'll give that try
댓글 달기
답변 1개
선택된 답변
The glue on older iPads can be dried out and it can be really strong. You need a lot of heat (80 degrees Celsius) to soften the adhesive. It can help to apply a few drops of IPA or rubbing alcohol along the sides, it wil soften the adhesive as well. Do not pry too hard, if it does not lift easily you will damage your screen. Life hack: back in the days when I did not have a heat mat I used my party grill with a flat plate on low heat. Just keep it below 100 degrees to protect the screen and plastic parts. The iOpener also works well, but the iPad’s case dissipates the heat really quick. It can help to heat the entire iPad to help the iOpener a little.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Joe 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 41
