주요 콘텐츠로 건너뛰기
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
159 질문 전체 보기
Xbox One analog drift but not the usual one
Common problem, the right stick is drifting upwards. However…
I desoldered the right stick, turned on the controller and even physically without the stick it was still drifting. Then I installed a new analog (entire new unit not just the potentiometers), and it still drifts like if we were in the 90s.
Send help, no visual problems on the board, however the main motor red cable was desoldered when i opened it up, but i dont see how it may affect the controller in any serious way. Btw the controller emits rather quiet buzzing sound tho I heard it’s normal.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
I have the same problem
댓글 달기
답변 2개
선택된 답변
Missing resistor or a broken trace can cause this issue.
Check for shorts in the near of the sticks
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
This is a problem with the specific build your xbox is on, I had this months ago on a preview build and it was fixed in the next couple updates, it's abysmal that microsoft even allowed this update to go out on the “Stable” update cycle. Literally game breaking. On a box designed to play games. Stupid. Just keep updating it gets patched out.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
So you are saying that
I've been disassembling and reassembling this thing like an idiot this whole time for it to be a firmware error? lmao
Yeah, the problem is still present on PC and XBOX to this day so it's not the case i believe
댓글 달기
귀하의 답변을 추가하세요
Szczepan Ciołkosz 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 515
