주요 콘텐츠로 건너뛰기
2011년 하반기 모델, A1278 / 2.4 GHz i5 또는 2.8GHz i7 프로세서.
646 질문 전체 보기
Can I use a mid 2012 13 MBP screen on the late 2011 model?
I’ve seen people using a 2011 screen on the 2012 model but is it possible to do it the other way round?
My 2011 screen died on me and I have a broken 2012 lying around.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 2개
선택된 해법
As long as they are both Unibody systems! You can’t use a Retina display on a Unibody.
Be aware the 2012 systems use a slightly different LVDS connector!
Most people are placing the 2011 15” hi-res matte or gloss displays onto their 2012 system. Here the LVDS cable tang needs to be ground down a bit, so it can fit. If done correctly there is no issues.
Here you’re doing the reverse! The 2012 display LVDS cable is a bit smaller so make sure you’ve centered the cable in the connector otherwise you risk shorting out!
Frankly, I don’t think its wise as you could damage your logic board and the display! The 2011 & 2012 displays are no different otherwise!
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Thanks for the tip! I didn't want to risk damaging the logic board so I actually just re-seated the display and it works for now. Would have to eventually replace the screen but I'll leave that for future me to worry.
의견 추가하세요
가장 유용한 답변
Should be all good might be bit hard to connect it.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Darren Yeo 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 26
