My control does not turn up or charge
the controller doesnt turn up or charge ,not even the led indicator,is a almost new controller and i have no warranty ,what can cause the problem o something like that
좋은 질문 입니까?
좋은 질문 입니까?
how new is new? you cant return it to the store?
have you tried changing the cable to charge it also the power brick.
check the charging port on the controller to see if there are any bent pins.
does anything happen when you plug it in at all? (lights flicker or come on and then turn off?)
해당 답변은 도움이 되었습니까?
it had like 3 months ,yes i had tried with diferents way ,and not even a bent pin, and it does nothing at all ,not even a spark of light and i am here because return this will cost me 70 dlls
only other thing i could say would be to open the controller up and look at the charging port
you can follow this guide and buy parts from this site itself.
DualShock 4 Charging Port Replacement
good luck!
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 24
