주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
4086 질문 전체 보기
My iPhone 5s doesn't recognize simcards anymore and I cant activate it
Hi
I found my old iPhone 5s and suddenly realised why I needed a new phone back then. It doesnt recognize any simcard anymore. It kept saying searching, and I messed up when I tried a factory reset, cause after I did this, the phone had to be activated again, but it won’t without a simcard. I guess my question is, is there any way to activate my iPhone 5s without a simcard inserted? It just says “iPhone couldnt be activated, updates are required”. I’m also open to resorting to jailbreak if thats the only possibility I have left.
What I have tried is put the phone in recovery mode and tried to activate it through iTunes, but this did nothing.
Please help me out!
Thanks in advance,
Best regards,
Naomi
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
It sounds like a baseband CPU issue and would be too expensive to get repaired if it can at all. You can confirm this by inputting *#06# into the keypad if it doesn’t bring up your IMEI it is most likely baseband.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Nope, that does nothing and says I can only make emergency calls.
@naomiphone5s Time to upgrade to a newer model.
의견 추가하세요
귀하의 답변을 추가하십시오
Naomi 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 11
