주요 콘텐츠로 건너뛰기
A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 또는 3.6 GHz quad-core i7 프로세서. 2017년 6월 8일 출시.
176 질문 전체 보기
2017 led model, can I upgrad
I have one: Apple iMac 2017 Screen 21.5 "intel Core i5 dual core 2.3 GHz (Turbo Boost up to 3.6 GHz) 8GB 1 TB Intel Iris Plus, has 02 memory slots, each with 4GB each. memory is: 8 GB 2133 MHz DDR4 integrated memory model: - Part number: MMQA2 (NOT RETINA) It is 2017. This model here: https: //support.apple.com/kb/SP758? location ... Can I install a 1 TB SSD with 32 GB of memory? I see that on the Apple website it says that the maximum I can put is a 256 GB SSD and 16 GB of memory. What do you think?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Yes this iMac can support up to 32GB of DDR4-2400 or 2133 unbuffered, non-ecc RAM, and as long as the SSD is SATA (a straight 2.5” SSD or a NGFF with the proper adapter) it will read and work. Apple’s website will only say what amount of RAM and storage they offer for that particular model.
Fair warning, I’ve been successful with these so far and I’d still rather not do this one. So buckle up and good luck!
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
Stick with the Apple blade SSD or OWC SSD, M.2 SSD's don't play well in iMac's. I've had to pull out quite a few.
@danj The price is what makes it so appealing, sadly; ignorance doesn't help. I can get a 1TB NVMe SSD (and the adapter) for my 2014 15" rMBP for less than the actual Apple 1TB SSD, and upgrade from the original 512GB SATA based SSD. The problem is sellers don't disclose it doesn't work for obvious reasons.
Surprisingly this model still uses 2.5" SATA drives. I was shocked the first time I cracked one of these buggers open.
It will also work with a M.2 SSD in a 2.5" SATA adapter, but only the SATA/AHCI ones with the B and M key. It was a customer's request because he already had the M.2 SSD. I didn't think it would work. Thermals are probably messed up though
Pluggin in a mSATA SSD into the SATA connection than plugging in a 2.5" SSD into the SATA port So while odd that's not a biggy. The real issue is the custom port on the other side!
Here's more on it The Ultimate Guide to Apple’s Proprietary SSDs
But didn't they skip the proprietary port on the 21.5" that year? Haha honestly asking cause I swear I don't remember seeing it on the back of this model.
Edit: Rocketyard reports that the stock standard version did not have the proprietary port, but it was on models that were configured with a fusion drive.
https://eshop.macsales.com/blog/41360-un...
댓글 달기
귀하의 답변을 추가하세요
yagokennedy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 131
