Phone fell into water?
My phone fell inside the toilet now its screen is green. Can I still save it ? It turns on sometimes but then gets back to the green screen quickly.
좋은 질문 입니까?
좋은 질문 입니까?
Hi @elenaglbrt
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your phone. Samsung Galaxy S7 Edge
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
해당 답변은 도움이 되었습니까?
Hello, I cannot take my phone into parts because of all the battery and other stuff built into the phone so I have to heat it and remove the back which is impossible for me to do that by myself. I cannot see the screen properly because of green screen so I don't really know how I can turn it of ?
Try the following:
Press and hold the Volume Down button and the Power button (both buttons together) for about 7 seconds.
Release the power button, then the Volume Down button.
The phone should now be powered off.
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 69
