iPhone X Screen Replaced - Black Screen - Can't Hard Reset
Hi,
I replaced the screen on my iPhone X. I checked the connections and the new screen worked and it powered on. After I added the metal casing over the connections and cable, I can not power the phone back on. The screen is 100% black. When trying to hard reset a loud piercing alarm-type sound gives a short burst, but nothing past that. I took the metal casing off and re-checked the cables.
What could I have possibly broken?
iTunes does not recognize phone as well.
좋은 질문 입니까?
You have put back the screws at the right spot, there are long and short screws.
Leslie Leslie 의
I am certain there are some in the wrong spot, but everything things seems secure and connected securely. Would a wrong size screw used prevent the phone from turning on? The screen was tested on another phone and it works fine. I am paying someone to test the circuits now. I’m stumped.
Jessica 의
@legtysgirl could be long screw damage to the logic board.
daniel 의
Oh, man! That makes so much sense ?♀️
...hopefully not.
Thank you for explaining
Jessica 의
@tech_ni Yes, you are right. Damaged Logic Board :I
Jessica 의
댓글 1개 더보기
