주요 콘텐츠로 건너뛰기
The Frontier was introduced in 1997 for the 1998 model year as a replacement for the aging 1986–1997 Nissan Hardbody Truck.
11 질문 전체 보기
1998 Frontier wont stay running
when I push the gas pedal, it dies!!..seems like something is clogged up
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Check your fuel filter. Probably needs replaced. If that doesn't solve it check fuel pressures to see if your fuel pump is going bad. It sounds like it can't get enough fuel when calling for more.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thank you!..I changed the fuel filter which was a 16 min job, and I’m a girl…so it was FUN!!..and that worked!.the truck had been sitting for awhile, and the gas was old and turned to goo,…so I put some fuel stabilizer and a new filter and it fired right up!!…yay!!..if I have anymore questions I’ll give ya hollar!…hehe
If it has been sitting a long time, I would highly recommend emptying the tank and filling with new. Use a good fuel treatment to make sure everything is cleaned of varnish from sitting fuel. Fuel filters aren't fun, but they aren't as bad as some things. Even my old chevy isn't horrible. Isn't easy but not horrible.
댓글 달기
귀하의 답변을 추가하세요
Tudi Goins 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 23
전체 시간: 900
