주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 2.6 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.2 GHz). 2013년 2월 13일에 출시되었습니다.
119 질문 전체 보기
Battery or DC in Board?
Put in larger SSD, machine ran no problems. Now DEAD. No gong, no fans, nada zip. Did SMC reset, still dead. Tried different charger, still dead. MagSafe shows amber light. SMC reset turns it green, then goes back to amber. Removed battery connector and tried to start with just charger cable, no battery; still dead. There are 4 gold contacts on top of battery connector:
I get ~3.25v on each side, total ~6.4V. I assume but don’t know that this is the total power from this battery. New replacement battery from iFixit has 11.21V. So the question is: Is it the DC in board that isn’t charging the battery, or the battery is no good? How can I tell? Can I test the DC in board somehow?
Many thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Hi,
I think the DC board is fine as the charger turns orange, which means the charger is detected. Seems like the battery has had it. Or you might have not plugged all the cables in properly. Please check all the cables are seated properly. You can also check when plugging in the charger if the charge level on the battery is rising. Also try booting without the battery.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks! Surely there must be some way to test the battery but I haven't found it yet. This occurred after putting in the upgraded SSD. It ran fine for a while, so can't be a cable issue, plus only the SSD cable was detached and re-attached, no others. Tried booting without the battery connected (complex connector, non-removable battery for this unit), no boot. Can't check the charge level because I can't boot and see any battery monitor.
댓글 달기
Okie Magic works again!
I took it apart and checked the DC-in and logic boards for corrosion, burnt parts and such. Nothing. Cleaned VERY thoroughly around the MagSafe connector on the computer. Also scrubbed the pins on the charger side of the MagSafe and ran some alcohol through the spring-loaded pins. One of the pins seemed maybe slightly sticky?
During reassembly I saw a slightly oily film near the AirPort card (separate from the logic board). Took off the AirPort card and there was some similar fluid under that on the non-absorbent foam pad on the underside of the card. Cleaned that all up. Got it all back together, fired it up and it worked just fine. I have NO idea what I might have fixed or not fixed. System profile software says battery isn't even to 1,000 cycles yet and is in good condition. Problem solved, no idea exactly why, but can't argue with success. Better to be lucky than good.
Thanks all for your help and for being on this forum to help us less talented folks.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Robert 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 40
