주요 콘텐츠로 건너뛰기
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
295 질문 전체 보기
Device not charging when off, but charges when completely off
So my iPad Air doesn’t charge at all when it’s on, and when I plug it into my computer, it shows the USB not recognized or malfunctioned. I’ve tried it on another computer, used different genuine lightning cables, same result.
However, when shutting off the iPad, it apparently starts to charge (according to the readings (Volts and Amps) on the Battery Activation board. I have updated it to the latest iOS but nothing has changed. So to summarize, it does not charge when the iPad is on, but does charge when completely off. What would be the problem in this instance? Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
If you used a particularly cheap cable from Amazon, eBay, Wish, AliExpress, or any other retailer that sells cheap cables, you might have damaged TriStar. What happens when you flip the cable’s orientation around? Does the same issue happen? For context, TriStar is a USB validating chip. Apple designed that chip to detect whether or not the accessories you’re connecting are certified, even from aftermarket manufacturers. The reason being is apple designed a special circuit board that is attached to the lightning connector that talks to TriStar. On this proprietary circuit board there’s built in surge protection. Apple sells this circuit board to third party manufacturers and cheap accessory manufacturers don’t have proper surge protection which results in damage to TriStar and can lead to the issue you’re experiencing. There’s a tool you can buy to test it yourself but they’re around $150 or call around your local repair shops and see if they have a TriStar tester.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Remy Stark 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 54
