주요 콘텐츠로 건너뛰기
Model No. A1367 / 8, 16, 32, or 64 GB capacity
910 질문 전체 보기
Hold switch not working after replacment
Hi
I have just replaced the volume and hold buttons on an ipod touch 4th gen. The old ones worked, but I snapped the thin cable when working on it so had to replace it. Now the volume buttons work, but the hold switch will not. I have checked the solders and they're fine. I think the replacement may be defective, because I cannot think of anything else. If anyone has any suggestions I would love to hear them as I do not want to wait three weeks for another hold switch.
thanks alot
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
의견 추가하세요
답변 1개
가장 유용한 답변
If the solder is fine. Did you check for small tears in the cable?
Make sure there are no solder bridges or loose components near the solder area. If all is well you will likely have to order a new one
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
matt prior 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 579
