주요 콘텐츠로 건너뛰기
iFixit 최적의 즐거움을 위한 비법과 요령.
26 질문 전체 보기
How do I put the swivel top back onto the aluminum screwdriver?
Hi I have an Ifixit aluminum driver with the swivel top coming loose and it's the second one I've gotten and happened to both of them so how do i prevent it from happening or fix it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
I had this happen on a few of ours. Bearings were fine, just seems like the top is pressed over the bearing and it wears loose after a while. I just put a thin layer of jb weld (doesn’t need to be this, just what I had) around the inside of the cap and pushed it back on, let it dry for about an hour and bam. Never had one come off after doing that, just make sure you don’t put too much of whatever adhesive you are using on there, you don’t want it squishing over onto the bits that need to move at it could cause it to lock up.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Erik Ruffalo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 28
전체 시간: 451
