주요 콘텐츠로 건너뛰기
1.5 Core Solo, 1.66 또는 1.83 Core Duo, 또는 1.83 또는 2 GHz Core 2 Duo 프로세서
141 질문 전체 보기
PRAM Battery Not Working
A Mac Mini I have wasn’t saving the date and time/wifi so I ordered a new PRAM battery. I put it in but the date and time/wifi still isn’t being saved. I flipped it around but the same issue occurred. I have pushed the metal fingers as close to the battery as I can, yet it still wiggles a little bit, so maybe that’s why? I tried it on another A1176 I have and the same problem.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 5개:
What is the batter markings?
It sounds like you either got the wrong one or its bad
@danj I bought the ones that were in the guide
@Jordan Baron - What is the batteries markings?
@danj Energizer CR2032
@Jordan Baron - Well, that's the correct battery, why I pressed was there is a thinner battery which is only 1.5v.
Your comment "yet it still wiggles a little bit" made me question if that was your issue. At this point your logic board socket maybe damaged as the battery is firmly held.
댓글 달기
답변 1개
Before you return what sounds like a bad battery, open up the date and time preferences and make sure you have the “set date and time automatically” checked.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jordan Baron 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 49
