Why is my phone not charging?
My samsung a31 phone not charging
좋은 질문 입니까?
Well, mobile is not charging is mainly happen because of the bad charger. Now the first thing you should do is to change the charge and then if it is not working then the charging jack of your mobile phone can be the cause replace it from a mobile repairer Your mobile will get starting charge.
해당 답변은 도움이 되었습니까?
الهاتف دائما يعيد التشغيل والشحن يسقط بسرعة
Try to reset it if it didnt work change the battery
Well you can try the following it might help you out:
해당 답변은 도움이 되었습니까?
Some times my mobile not charging, after restart the phone it starts charging
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 4
30일 전: 15
전체 시간: 1,359
댓글 2개
Solw charging
Ashebir Makunnt 의
3 month ago in my phone no charge
=== Update (08/09/23) ===
No no charge is there in my phone
My phone is dead thanks
Adinath Panchal 의
