주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3483 질문 전체 보기
Why does my iPhone constantly vibrate when plugged in? No display.
So this was a phone given to me by a friend. The power button didn’t appear to work so I suggested a replacement. It did this wierd thing where it would only hold a charge to 2% when plugged in and switch itself off. So I replaced the volume flex and now there is no disaplay but when it is plugged into power, it just vibrates. It started as a contiuous vibration, but now it’s more like a phone call - intermittent. I had thought about changing the battery to address the charging issue, but I can’t seem to get my head around the vibrating situation. Any info would be helpful, thanks!
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
This is a hated issue where if the battery gets over a certain % it kills itself. It can either be the battery, software, charger or blown cap or resistor. Try turning off battery percentage and turn it back on, try different software and finally change chargers. If all else fails take it to a repair shop as this can be a tricky subject
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Brandon Frost 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 7
