주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz) 또는 2.5 (Turbo Boost 최대 3.7GHz) GHz 쿼드-코어 Intel Core i7 프로세서.
467 질문 전체 보기
Replaced battery-it won't turn on after shutOff
EDIT 07/03/2021 02:45 PM:
After waking it up and a few minutes of web browsing the battery is now 100%
EDIT 07/03/2021 02:00 PM:
I did 15+ hours of continuous charge. Below what’s CoconutBattery says about.
EDIT 06/03/2021:
added image
Good Day Everyone
I’ve just replaced the battery with a kit, work was fine. I turned it on performed some tasks and turned it off. I made an SMC reset and it won’t turn on, not even fans after powersupply connected. I found a temporary solution disconnecting and reconnecting the battery plug (2 to 3 mins between those steps). Then after plugging the magsafe (light is functioning properly) fans spins and it boots.
At the present I’m performing calibration to see if changes.
Any suggestion? previous experience?
Thx alot ?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 4개
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 기존 질문에 이미지 추가하기
Hi Dan, thanks for reaching out, I added the image.
Thank you
@Alessio Cazzaniga - Leave it charging for a good 14hrs, then take another snapshot posting it a well. Lets see what it does.
Hi Dan, did 15 + hours so far. The screenshot is on my opening post.
Many Thanks
댓글 달기
답변 1개
가장 유용한 답변
Well, your battery and the charging logic is just fine!
So we need to run diagnostics as you have a different issue. You likely damaged something in the process.
Restart your system and press the D key to enter, let us know if you get any errors.
Reference: Mac startup key combinations
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
seems that the power button is not working..
I tried to turn it off the hard way (keeping it pressed) but nothing happens.
Might be just that button damaged with some adhesive remover liquid leaks or can that be the SMC?
@flutur_8 - Likely the keyboard got damaged ;-{
@danj yep it seems so
diagnostics run fine.
Can that single button be fixed somehow or need to replace the keyboard?
Thx Dan I appreciate Your Support :)
@flutur_8 - Hard to say, time to find someone with deeper skills to help you here.
댓글 달기
귀하의 답변을 추가하세요
Alessio Cazzaniga 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 42
