주요 콘텐츠로 건너뛰기
The Kenmore Elite HE3 is a washing machine by Kenmore.
668 질문 전체 보기
Kenmore elite top load washer uneven
I have a kenmore elite top load washer that frequently gives me the uE or UE code. Normally, I can rearrange the clothes and finish the cycle. We used the sanitize setting with NO CLOTHES to clean the washer and continually got the UE code so that we could not even finish the cycle! Please help! Thank you!!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
Hi @ttap14,
What is the model number of the washer?
The model number is 796.3152
@ttap14
Does the washer move or the tub "bang" during the spin cycle at all?
댓글 달기
답변 2개
가장 유용한 답변
@ttap14 @jayeff it could be the stator that causes this. I had to replace the complete stator in my Kenmore HE3 due to a wore out hub. It would trigger the UE code first only sometimes and then just much more often until it finally would not work at all. I suggest you go ahead and check it out. Post some good images of what you find on the hub and spline. 기존 질문에 이미지 추가하기 See if it is wore out as well. It is not a terribly complicated job but definitely works better if you can lay your washer on its back etc. Use this Elite HE3 Service Manual to work on your washer. Page 53 part number K201 is what I had to replace. Wasn’t easy to find for my model and you definitely need a big wrench and a big hammer :-)
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
there are a lot of answers available if you google Kenmore Elite HE3 UE code.
try that first.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Trapper 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 18
전체 시간: 713
