주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1207 질문 전체 보기
iPhone 7 bootloop, only when screen is pushed down.
So, I have an iPhone 7 Plus, it’s a customer’s device, so the speed is crucial, but the issue I am facing is that the screen works perfectly. touch and everything, until I push the screen down, when the screen is open, it’s working, but boot loops the second it’s pushed down.
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Hi there, just ran some tests and found that the earpiece speaker doesn't work,. Could this be part of the problem?
의견 추가하세요
답변 2개
가장 유용한 답변
Disconnect the top flex cable and seat the screen if it boots it will confirm a faulty top flex assembly and it will need to be replaced. This is the most common cause for the 7 series to boot-loop.
 If it is not the top flex assembly it will be one of the other flex cables causing it, most likely the home button cable. The bottom cables cannot be replaced and require a replacement screen.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
Several problems can cause the bootloop. if the restore didn't work, you could have a battery or card failure. the battery may not have enough juice to pump into the operating system, in which case it will fail. the power button could be shorted. or you might have physical corruption in the image chip.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
is there anything I can do, it is wierd that when its not closed it works perfectly fine
의견 추가하세요
귀하의 답변을 추가하십시오
David bellows 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 19
