주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.0GHz, 2.3GHz, 또는 2.6GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.8GHz).
514 질문 전체 보기
Why does my screen not remain closed?
My MBP screen won’t remain closed — it “pops” up after closing it.
This began right after I took it to the Apple Store to replace some missing screws on the bottom cover. I’m not seeking to assign blame here, just get my screen to remain closed.
Any ideas? Thanks in advance.
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
I hope you are a good Sherlock!
Find a good flat surface as you need it to reference (a single slab of stone or glass top table). Make sure your feet are all present and are uniform (no off the wall solutions)
With the system sitting are the feet all setting firmly on the table surface? Does it wobble? With the lid open you might be able to straighten a slight bend (more than a 1/16th of an inch will require a taking the bottom cover off)
Now you’ll need to take the bottom cover off and locate the screws which hold the screen. Follow this guide MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement After doing the first four steps, jump down to Steps 9 & 10, then jump to Step 12 just loosening the six screws, then tighten them up again did that fix things? If it did button it up and check again.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Bill Doerr 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 6
