주요 콘텐츠로 건너뛰기
The Samsung Galaxy A40 was released in April 2019.
28 질문 전체 보기
Black Blobs Appearing on Phone Screen, Can't Access Anything
Hi there, I’m kinda pulling my hair out trying to figure out this mess I’ve gotten myself into with my Samsung A40. My phone hit the ground hard by accident and despite no visible cracks, black/purple blobs have started spreading throughout the screen. Worst of all, touch screen functionality has ceased and I’m stuck in the Lock Screen. Rebooting it doesn’t work, which isn’t aided by the fact that the volume buttons don’t work to reboot it in the first place, so I had to run it out of charge to restart it. Alas, the touch screen still won’t function and the blobs are spreading.
I understand there may be damage to the AMOLED display, but I’m no expert on this. I have a lot of files stored internally that I never got around to backing up elsewhere and I’m very scared of losing them. Is there anything I can do to get into the phone and grab my stuff before the whole screen becomes unusable? Should I turn it off until I know what I’m doing? Is there any course of action I should take to help mitigate this problem? Thank you so much for your time.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
chances are that the battery is damaged and has expanded, causing it to push against the underside of the screen. perhaps replacing it will fix it, but you will likely have to replace the screen as well, however those are relatively easy fixes
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I understand, I'm glad to hear it's hopefully not as unsalvageable as I worried it might be. I'll keep trying to identify the exact issue and if I can't sort out those fixes myself, I'll seek out a repair shop in town that can replace what's broken. Thank you!
댓글 달기
귀하의 답변을 추가하세요
biological frog girl 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 132
