주요 콘텐츠로 건너뛰기
Is there a logic board diagram?
I was replacing the fan (why did it overheat?) and noticed a disconnected plug at the top. I don't know when it got unplugged but I was also getting a 2STF/1/4 (no hd) error and wonder if it was because of the plug.
thx
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Yes the plug you describe is the hard drive ribbon data cable. It snap under the logic board. The cable brings power and transfer data to the hard drive. Snap it in the connector and put a tape on it so it will stay in place.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
가장 유용한 답변
I'm including the takedown guide for your computer. I think if you follow it though as if you were replacing the logic board you should find the plug and its use. If you are not properly booting you should try booting with your system disk and run disk repair to see if you can clrear the error message. Good luck--Ralph
iBook G4 12" 800 MHz-1.2 GHz Repair
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
johnman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,014
