주요 콘텐츠로 건너뛰기
모델명 A1707. 2017년 6월 출시, 이 MacBook Pro는 Kaby Lake 프로세서 최대 2.8 GHz 쿼드코어 Intel Core i7 프로세서와 Turbo Boost 최대 3.8 GHz를 사용합니다.
324 질문 전체 보기
MacBook Pro Display glitched after hours of used and turned black
My Macbook Pro 15” 2017 would become glitched after hours of use.
I tried to use external monitor and it still worked perfectly without problem after the glitched display turned black.
The brightness setting still working as well, I can see the display brighter and dim, also the front camera still running perfectly as well.
The glitch first looks like a vibrating LCD up and down but the interface or HUD of macOS didn’t affected. But, after updating the OS version the vibration no longer happen but it still glitch white screen blinking.
As I type this the display is turned black. I assuming the problem not come from the LCD but some part of the display or possibly the software. If anyone have a solution or have experienced the same please help me.
Replacing the whole display could cost a lot :(
Update (07/21/2021)
Here is the video of display changes
I’ve posted the video of the display issue, maybe you can check it out, thank you
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개:
Can you post a short vid as the display changes from working to not 기존 질문에 이미지 추가하기
I have the same problem ( but just when i'm playin' a vidéo on it or using a software that displays animated stuff : video and sound editing softwares + websites like Youtube and dailymotion ...etc)
댓글 달기
답변 1개
Ouch! The displays T-CON board has failed! Sadly you can’t replace it alone, you’ll need to replace the fully display assembly:
And here’s the guide to put it in MacBook Pro 15" Touch Bar 2017 Screen Replacement
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kevin Saptadjaya 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 103
