주요 콘텐츠로 건너뛰기
9월 20일 출시된 Apple의 2019년 주력 스마트폰으로 5.8" OLED 디스플레이, 트리플-렌즈 후면 카메라 및 크게 향상된 배터리 수명이 특징입니다. iPhone XS 의 후속 제품입니다
39 질문 전체 보기
iPhone stuck in restart boot
Hello, i ordered a screen off of here for my buddy that ran over his phone. After installing the new screen the phone would restart itself every 5-10min. I checked the proximity sensor for a possible damage to the ribbon cable that was transferred over and the camera function etc and everything seems to be fine. I did notice slight damage to the battery of the phone and was wondering if that could cause the restarting issue? The phone takes a charge with little amount of heat.
Update (07/22/2021)
I’ve also tried hard resetting it, updating it, restoring it. To no prevail
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
답변 1개
가장 유용한 답변
If the phone restarts a few seconds after shutting off I doubt it would be a battery issue since the battery would only be out of action for a few seconds, which if the battery was the problem I would expect it to take a lot longer to start booting again.
Try unplugging the ear speaker cable completely and test the phone. Face ID will not work with it unplugged however it will narrow it down whether or not the ear speaker assembly is the component causing the restart.
If the phone still restarts with the ear speaker unplugged, try unplugging flex cables one by one until the issue stops, which then it can be confirmed which flex cable may be causing the issue (all flex cables besides the ones which are important for the phone to boot, like screen, power button and battery). Make sure to turn off the phone and unplug the battery before unplugging anything.
However, even after unplugging everything and the issue still persist, it may be a motherboard issue. Try seeing if you can feel the motherboard getting really hot somewhere around the time it would restart, which if you can feel it getting hot there may be a short. From there the phone will need soldering work.
Hope this helps!
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Jordan Allen 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 33
