주요 콘텐츠로 건너뛰기
모델 A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, 또는 2.4 GHz Core 2 Duo 프로세서
1203 질문 전체 보기
Magsafe Board changed...No power!
I'have changed the Magsafe board. Magsafe LED is green,
But no power
Reset SMC
connector keyboard ok
It's a MacBook 2009 white. I think that the keyboard does not function, and i dont find power connector on the logic board.
thank you for your help
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 2개
Please give us the last 3 characters of your serial number so we can verify your exact machine.
It' a early 2009 the Keyboard was changed and the serial is on the Keyboard
댓글 달기
답변 1개
가장 유용한 답변
Check the voltages at the battery connector using a multimeter or similar. The two outer pins are ground. The three inner ones should read something around 3,5 V. If the machine suffered a spillage have a hard look at the Magsafe -> board connector and also at the Board -> battery connector.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
The 16.5 VDC, pinout is on the right side of this link: http://en.wikipedia.org/wiki/MagSafe
댓글 달기
귀하의 답변을 추가하세요
Mikhrych 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 437
