Blinking battery lights, Asus laptop wont turn on
Hi everybody I need some help.
I had an Asus laptop K550V and the charger was faulty recently (it has to be placed at a certain angle to charge).
I replaced it with a new one, and now it charges fine - with the battery light turnning yellow.
But the laptop wont turn on. The power light will turn on, the fans will kick in, but the screen is black. I tried the hard reset 30-second power button hold but it did not work. Also, before I turn it on the battery light is solid yellow, but when I turn it on it starts blinking slowly.
Is there any fixes? It is currently lock down in my city so going to a shop is not an option, and i need this to work.
좋은 질문 입니까?
댓글 5개
Hi,
What is the model number of the laptop?
jayeff 의
@jayeff It's a K550V
Hai long Pham 의
I have two questions
1. when you tried the hard reset did you disconnect the battery?
and 2. have you tried connecting to an external monitor and seeing if maybe it's a display related problem?
Hyrum Lowry 의
@master_hyrum Hi, thank you for your reply.
1. I tried both actually, same result
2. I did, I have one around. The thing went straight to power mode, so Im not sure
Hai long Pham 의
I have the same problem. Asus vivo book s14.
did you find the solution?
Maha 의
