주요 콘텐츠로 건너뛰기
2011년 하반기 모델, A1278 / 2.4 GHz i5 또는 2.8GHz i7 프로세서.
584 질문 전체 보기
MacBook giving beep code every 5 seconds when bottom cover is on
I have a Macbook Pro Late 2011 that I replaced display on and upgraded the RAM with PC3 10600 tested it out and did PRAM before putting the bottom cover back on booted no issues. But once I put the bottom lid on, it’ll work for bit then when I turn it back on again it beeps every 5 seconds. When I take the coveroff no issues. I then took the battery out and put the bottm cover back on and had no issues with it turning on and haven’t gotten the beep code again. Is that normal for a battery to do that? Could it be the display? Or something lese?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
1 Comment
What is the number of beeps?
FYI: If your Mac beeps during startup
댓글 달기
답변 1개
선택된 해법
That one beep indicates no RAM. Try reseating it.
해당 답변은 도움이 되었습니까?
점수 3
3 Comments:
I have but it only happens when bottom cover is on
Is your battery swollen at all? Is the bottom case dented in?
Sorry for delayed response, the battery was fine but it's weird though I reseated the LVDS cable and everything worked.
댓글 달기
귀하의 답변을 추가하세요
Chris 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 32
