주요 콘텐츠로 건너뛰기
Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
136 질문 전체 보기
DSi XL Destroyed P10 Connector Where to Bypass?
First ripped off the latch, then broke the latch trying to put back on. Tried soldering ribbon cable to remaining prongs with no success, melting the connector.
Removed the connector and ripped off the pads trying to clean the melted plastic off.
Board is now clean but missing 3 of 4 pads and replacing the connector is out of the question I believe.
I would like to solder wires from the ribbon cable to points on the motherboard bypassing the connector/pads.
Anyone know what chip legs/components I could use instead?
|1|2|3|4| - (picture orientation) ribbon traces.
CAT5 wires to connect from ribbon to components on MB.
|x|x|x|4| - (picture orientation) 4th pad left but sitting loose and just about broken off. (X traces/pads on the motherboard broke off)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
선택된 해법
youll need solder jumper wire, solder mask and some steady hands.
check out this video, he has others about how to do jumpers properly also.
https://www.youtube.com/watch?v=ZFBSVfh-...
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Thank you for the info and Video. I will take a look at the other videos and see about the jumpers. :)
의견 추가하세요
귀하의 답변을 추가하십시오
Adam Flett 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 17
