주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
질문 마감됨
iPhone 4 home button works poorly after a small water spill?
Hey all,
New to this site, can't believe a great site like this exists!
So here's my problem...
My girlfriend spilt water on her iPhone 4 (GSM) just so its clear.. about 4-5 months ago.
Ever since the water spill, the phone's home button does not work well.
What do I mean? - Well it does work, but only if you press on it quite hard, specifically the pressing has to target the center upper edge of the button. That is the only way it is functional at all. As you can imagine doing a "hard reset" is a HUGE pain in the butt, because you can never be sure if the home button is activated or not.
I was wondering if simply buying a new home button from this great looking site, along with any other necessary materials will be sufficient to fix this problem?
Well thats about it..
Looking forward to your answers,
Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
Replacing the home button should work for you.
My problem was similar. After almost a year of use, the iPhone 4 home button became less responsive. I had the phone sent for repair and moisture was detected inside the device. As the warranty was void, I decided to replace the button myself. It works like a charm now, responsive as on day one.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I got the same problem, where was the moisture found? On the home button, or on the sensor for the home button? Is this package enough? [연계 제품이 누락 또는 비활성화 됨: IF182-017]
Thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
No idea. All I know is the moisture sensor was triggered. This package should be enough. In case it turns out not to be, you could try replacing the dock connector as well.
댓글 달기
not working at o cant turn on after water
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
If the issue started after water damage you probably only need to disassemble the phone and clean the contact points between the homebutton flex and the connector on the dock connector and clean the back of the button and the frame contact point. This fixes 90% of them.
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 7,387
