주요 콘텐츠로 건너뛰기
Apple Macintosh 개인용 컴퓨터 수리 안내서 및 분해 정보입니다.
42751 질문 전체 보기
Problem to transfer video to iMovie 8 (camcorder with a hard disk)
It worked greate earlier.
I have problem to transfer video from my Sony HDV camcorder with a hard disk drive. I'm using USB cabel. No scanning contents will appear as it did earlier.
I also have a portable hard drive with exported clips from the camera, it does not work as before. This must be a software problem... any suggestions.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Maybe it is because my I mac is 9 years old,but I can't load my Videos from my Sony HD DCR-SR200 to my I mac to edit my video into I movie, I have an external drive, also I need to load a new version of Quick time Player. Is this hopeless or can I fix it?
댓글 달기
답변 2개
선택된 답변
Early model Macs (non-intel)
(you didn't specify your machine) only recognized Firewire DV in. If you had USB or Composite Video Audio out you needed a black box with a Firewire out to do iMovie.
Also you didn't specify the model of Sony DVD cam. http://esupport.sony.com/perl/model-...?...
If you click the link:
"How to connect the camcorder to a computer running the Apple® Mac OS® operating system."
in the FAQ/KnowledgeBase you will see that:
The DVD Handycam® camcorder is not compatible with the Apple® Mac OS® operating system.
If this answer is acceptable please remember to mark it.
Good Luck,
N.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I have used this I mac before many times and never had a problem is it because it is 9 years old>?
댓글 달기
Have you checked that this camera is compatible with iMovie? Many sony camcorders, especially their HD ones, are not compatible with mac, usually you unfortunately have to install the drivers somehow by either virtualizing, emulating, or installing windows (on a partition).
How does the camcorder save the video?
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Everything worked earlier. The problem is new, and the USB-cabel is ok!
So have you since modified your configuration at all? Software updates etc.?
Or has the camcorder or the card it uses to store data been damaged in any way?
댓글 달기
귀하의 답변을 추가하세요
Noppster 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,323
