주요 콘텐츠로 건너뛰기
10월 13일에 발표된 iPhone 12 mini는 Apple iPhone 12의 소형 버전입니다. iPhone 12 mini 특징은 5.4인치 OLED 디스플레이, A14 Bionic 프로세서, 그리고 듀얼 후면 카메라 입니다.
73 질문 전체 보기
Dies too quickly! Why?
So why does my iphone 12 mini battery die quick after 5 months?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
선택된 답변
İ kept it like that for a bit,and it actually (somehow),and it did stop doing that,idk how it fixed itself though,it did get normal even though it was before i was in 16.1.1,but after 16.1,so it wasnt an update
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
Check your battery health. (Settings>Battery>Battery Health.) From there check Battery health, Apple considers 80%+ to be optimal. if it is lower than 80%, consider having your battery replaced/replacing it yourself.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
well it says 99% battery health
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Sorry for the slow response.
If your battery is at %99 and already having issues I can only think of two possible issues. 1. a bug in whatever IOS version you are running is draining the battery. 2. There are app(s) running in the background causing your battery to drain.
Ways to fix:
For an IOS version causing battery drain, Down grade/Upgrade your IOS version.
For App(s) running in the background, close/uninstall unnecessary apps. (Each app's battery usage is viewable in your battery settings.)
Another thing to try would be a force restart.
Even though the guild is for a iPhone 11, it will work the same as a 12 mini.
(iPhone 11 강제로 재시작하는 방법)
I would also try calibrating the battery (To calibrate your battery. First, charge it to 100%, then use the device normally like you would until it drains to 0%, then repeat the process 2 times. Your battery should now be calibrated.)
If all four of these things are unable to get your battery to function properly, I'd suggest replacing it.
Hope this is of some help! :)
I have an apple iPhone 8, it says 99%, it’s been more than 2 years since I got it. also something is that I don’t have a phone plan, wondering if that makes a difference
댓글 달기
귀하의 답변을 추가하세요
KAAN CAN 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 62
전체 시간: 1,850
