which cable I must use to put SSD on iMac 21.5 4k 2019?
Hi. have iMac 21.5 4k 2019 (2020 update) want put Samsung SSD 250gb to install windows. which cable I must use? only cable is necessary or needs thermal sensor or something?
좋은 질문 입니까?
좋은 질문 입니까?
Uses the same SSD cable as the previous generations of 21.5” iMac . No additional temp sensors necessary as far as I know. Since you have an SSD only model, you may also need the 2.5” hard drive brackets for optimal mounting, since your unit likely doesn’t have them. It’s not as necessary with an SSD since no need to mitigate vibration, but I am always less than enthusiastic about leaving SSDs dangling on cables or taped into enclosures.
iMac 21.5" (Late 2013-2017) SATA Cable
해당 답변은 도움이 되었습니까?
will this work on my iMac? (I'm asking because once I bought Ram 2x16gb from amazon A-TECH and after MacOS update system blocked this ram and was restarting continuosly. then I put back apples original 8gb ram) also can't find this brackets you said. please provide amazon link if you can. thanks
Yep, that looks like the correct one to me! Also, the hard drive mounting hardware seems harder to find. I found a few things, but nothing on amazon, they may not make third party versions of this. This ebay listing is the thing I'm talking about (https://www.ebay.com/itm/144032586607), it actually looks like the OEM one, probably just taken from another unit, mounting screws might be another whole ordeal. There may be third party methods of mounting this, but I don't think it's common to need them since SSD only variants of the 21.5" are much less prevalent than Fusion drive or HDD only models. For all I know it will have this hardware already, but it seems unlikely to me. Like I said it's not vital with an SSD, but it would probably make mounting easier, and look much neater. Even if you're the only one who knows its there.
Finally I installed sedond SSD on iMac but now can’t install Windows here and please help. Boot Camp shows only main SSD. want install windows on second SSD which I just installed. no option to choose partition for installing win
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 206
4 Comments
Apple did not make a 4k in 2020. Go here and identify your EXACT machine and let us know what it is: https://everymac.com/systems/apple/imac/...
mayer 의
Need a bit more information. It depends on which storage configuration you have now. Is it one with just an Apple SSD? or a Fusion Drive? And I assume you mean you would like both macOS and Windows installed, but for Windows to have its own SSD (a 2.5” SATA SSD, I think)?
Alisha C 의
@flannelist iMac is 2020 UPDATED version without fusion drive, it uses Apple ssd 256gb. it's little storage for both system and don't want fully load ssd so decided put second ssd Samsung evo 850 250gb. need windows for some programs.
Ramaz 의
@mayer
here is link. it doesn't use fusion drive. just apple SSD 256gb. i7 8700 and 560X
Ramaz 의
