주요 콘텐츠로 건너뛰기
Samsung의 열 번째 주력 핸드폰, 2019년 3월 출시. Android 9.0 (Pie)와 함께 제공됩니다.
57 질문 전체 보기
My phone black screen and cannot be charged.
I often wipe the back cover of my phone with a wet napkin, and I often see that the rear camera will fog up. I didn’t take this seriously, but the phone camera suddenly couldn’t be turned on the other day. I thought it was a system update problem. Until today, my mobile phone suddenly couldn't be turned on in the morning. I tried to charge the mobile phone, but the mobile phone did not respond. I also tried various key combinations and it didn't work.
What surprised me was that I was able to manually open the back cover of this phone without a heated back cover. I see a little water inside, so I suspect that the phone's waterproof failure is causing this problem.
What I want to ask is how to detect what is wrong with the phone? Is the motherboard broken or the battery broken so that I can further repair my phone.
Thanks!
—————————————UPDATED-V2—————————————————
After I further disassembled the phone, I found that the motherboard had water in several places, as shown in the figure:
Several parts of the motherboard are obviously corroded and turned green. Can the motherboard be repaired in this situation? What should I do?
—————————————UPDATED-V3—————————————————
Unfortunately, I still cant’t turn on my phone after cleaning the motherboard.
What should I do now?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
@device_owner this “rear camera will fog up” and obviously this “a little water inside” would make me treat it as a water damaged phone.
For now stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.This may further damage your phone.
The next thing to do is to clean it. Disassemble your phone using these guides Samsung Galaxy S10 Repair . You must remove all EMI shields from the circuit board. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide , and even so it was written for a 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components, corrosion on the board etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. Once all this is done, reassemble your phone and reevaluate. Until it is cleaned, everything will only be a guess. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try. Change your cleaning habit and stay way from using “wet napkin” to clean your devices.
Update 11/22/2021
@device_owner now it could be time to check out the function of the board. You did get all the components on the board properly cleaned and you do have a new battery?
Start by following the flowchart
The PCB Layout will let you search for the components, like L8026, that need to be checked. Just use the search function of your PDF reader.
해당 답변은 도움이 되었습니까?
점수 1
6 댓글:
Thank you very much for your help and suggestions.
What confuses me is that since the Samsung S10 is IP68 dustproof and waterproof, why do I often use wet napkins to clean the front and rear panels of the phone, causing water to enter?
Do you think there is a problem with the motherboard or the battery?
This is my first time to disassemble and repair the phone. Although it will be a lot of challenges for me, I will try to repair my phone, thank you.
@device_owner my gut feeling says it's somewhere on the circuit board. If you take it apart post some good pictures of your board with your QUESTION
@oldturkey03 Yes, it is indeed a motherboard problem. I updated the question description and photos, I have to buy some isopropyl alcohol to clean these corroded parts, it seems that the battery is ok.
Thanks again.
@device_owner you are going through a lot of work so please do yourself a favor. Change the battery. It'll help you in the long run.
Clean the board well and after that proceed like I suggested in my answer. Hopefully we can then diagnose what is going on with it.
@oldturkey03 You are right, I will consider buying a spare battery after I fix the motherboard and the phone can restart. Hope everything goes well, haha.
1에 댓글 더 나타내기
댓글 달기
귀하의 답변을 추가하세요
Love Fix 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 234
