주요 콘텐츠로 건너뛰기
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 또는 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz 또는 Core i7 2.8 GHz) ID iMac11,1
Can I change the PRAM battery
Can I change this PRAM battery, or will I have to take it in for service? Mind you, I HAVE seen the disassembly of this beast. I have also looked @ What is expected life of the PRAM battery? Is it user replaceable?
The answers were ambiguous, and did NOTscratch the itch.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
time and date will not hold after closing down
댓글 달기
답변 2개
선택된 해법
Here's a picture of the location of the PRAM battery. iMac Intel 27" EMC 2309 and 2374 Teardown
Frankly I have yet to see one of these newer type PRAM batteries fail after 5 years. Before you replace it, please tell us why you think it is not working. The half moon piece of plastic that holds in part of the battery will snap off with just the lightest of pressure so slide it very gently out of the slot.
이 답변이 도움이 되었나요?
점수 5
댓글 8개:
hello, my imac late 2013 has some strange problem, and i want to ask if you think is from the pram battery. when i press the power button i hear that the computer starts...but it stay in blackscreen for 20-30 and only after that it comes to normal. this happend after i was on vacation and i unplug the imac from the snuff.
Vlas I would start a new question and give us your history and you exact symptoms. No, I don't think its a battery issue.
Hi, Vlas, did you ever get this figured out? I'm having a similar issue with my 2009 27" iMac: it boots, but takes a long time to do so (I even have an aftermarket SSD as my boot volume). When it finally does the screen may come on for 30-120 seconds, then goes dark, no icons, nothing. Wondering if it could be a dead PRAM battery as well.
Matt, hook up an external monitor. It should go out when your internal one does. This is most likely a GPU issue and it needs a reflow.
Thanks, Mayer. I did have my tv hooked up and it was out too. By reflow I assume you mean install a new one?
댓글 3개 더보기
댓글 달기
I'am about to upgrade my emc 2309 27' imac to 850 evo samsung ssd via optical bay, until I can afford to buy a ! tb. for my HHd , then I will put that in, but, I was thinking maybe I should change the pram battery also, because I've had time problems recently and I had to perform a SMC fix and alls been well until today when I had a Kernel panic but that doesn't necessarily mean it's the battery but I thought since I have to go in there, maybe I should change the battery as well! Any help or specific advice would be appreciated from anyone. Thank you! Al
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Richard Coffelt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 17
전체 시간: 21,238
