I replaced to power supply but still no LEDs or power.
I replaced the power supply on my IMac but I still don’t have any LEDs lit , nor power.
좋은 질문 입니까?
좋은 질문 입니까?
At this point you need to probe the power supply AC input connection with a DVM to see if the power is even getting to the power supply >> Just be very careful! << You don’t want to get the shock of your life!
So is the power supply getting power?
If it is then you need to check the power button connection which is part of the power supply control cable connector. Is the connection good is the cable damaged?
해당 답변은 도움이 되었습니까?
I should still at least get the first LED. None of the 4 are lighting up. I’ve tried different cords and nothing. Brand new power supply. One of the LEDs actually flashed but that was it.
Just like a doctor needs a Stethoscope to check your heart you need a Digital Volt Meter (DVM) to check your system.
The onboard diagnostic LED's only go so far, you need to follow the powers pathway to the power supply and then check the power rails on the logic board as clearly there is a disconnect or a short
If yo travel down this path you also need a road map (Schematics and boardview drawings) to help find you way.
For most people this is brain surgery! Best to let someone with deeper skills help you.
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 40
