주요 콘텐츠로 건너뛰기
The Kenmore Elite HE3 is a washing machine by Kenmore.
668 질문 전체 보기
kenmore elite 79629002000. Has no power but outlet has power
I can’t find fuse for kenmore elite model number 79629002000. Has no power but outlet has power please help
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Is that model the same as 996 or 796-40272900
댓글 달기
답변 2개
가장 유용한 답변
Hi @sharpjordan10,
Check that the Noise filter LG part # EAM60930601 (supplier example only) is OK.
The power passes through the filter (where there is also a fuse) to get to the control board.
Here’s the service manual for the washer. Go to p.20 to view the wiring diagram which shows where the noise filter connects to the control board so that you can test if there is power at the board or not.
If there is no power at the control board then the filter or the line cord is faulty.
If there is power at the control board then there is a problem on the board.
See p.21-22 for how to access the filter.
Be safety aware when testing as it is hazardous AC voltage that you’re testing for. If you don’t know what you’re doing, then don’t do it! Contact a reputable, professional appliance repair service and ask for a quote
The parts supplier linked above was only to show the part. There are other suppliers online that may suit you better. Just search for the part number only to get results.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi @Richard Lilygren
The 796-40272900 is the same inasmuch that it is a rebadged LG washer which according to this parts supplier it also has a noise filter part #6201EC1006T. This supplier shows that it is part #6201EC1006L but a quick search online shows that they seem to be interchangeable and are also used in other LG appliances as well.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
sharpjordan10 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 16
전체 시간: 760
