Fans stuck at full speed
Replaced the logic board and ssd in my MacBook and now the fan is stuck at max speed. I have tried to control the fan with Macs Fan Control but it doesn’t work and TG Pro is reporting normal temps but TG pro sometimes reports that the fan isn’t on because temps are so low.
I have tried reseting PRAM and SMC with no luck
좋은 질문 입니까?
댓글 2개
If you can run the onboard diagnostics, press the D key when you restart or better yet get the full version of TG Pro to get the diagnostic function as Apple messed up the diagnostics in some versions of the system firmware. In any case let us know what the diagnostic code is
Reference: Mac startup key combinations
Dan 의
The correct answer is mine
Dan 의
