short battery run time
On my 3rd replacement battery. Have followed all the calibration guidelines, but initial battery run-time was only 2 hours. Is this normal for a new replacement ? Is there something I can do to increase the run time ? Thanks for your attention. This is the CocoBatt view after first discharge phase of calibration of new battery
The is CocoBatt after discharge and full re-charge. Took 2 1/2 hours to full discharge.
좋은 질문 입니까?
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 기존 질문에 이미지 추가하기
Dan 의
mind telling us why did you change your battery 3 times?
Lock 의
@danj
see pix of early calibration phase of NEW REPLACEMENT BATTERY.
stevesamrob 의
@lockxh
First battery began to swell and press up against track pad, causing erratic trackpad behavior. Second battery retained charge for only about 1 1/2 hours and would only charge up to about 50% of design capacity. Both had been thru calibration sequence.
stevesamrob 의
