주요 콘텐츠로 건너뛰기
The Samsung Galaxy Tab A 10.1 is known by different models depending on the features. Regular model: SM-T580 (WiFi), SM-T585 (3G,4G/LTE and WiFi) released in May 2016 or S-Pen model: SM-P580 (WiFi), SM-P585 (3G,4G/LTE and WiFi) released in September 2016. It is a 10.1- inch tablet manufactured by Samsung Electronics and their new high-end “A” series.
Backlight Not Working After Replacement Parts
Hey everyone i have an issue with this tablet, it was dropped, I have replaced the screen, ribbon cables both the primary and lcd ribbons, the charger port, the battery and yet I can hear the tablet works, the touch screen works but there is zero backlight and I know the screen is working in a previous tablet, im at a loss at why im not still getting any backlight on the screen.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi,
Try shining a torch at an angle close to the screen and check for images when the tablet is on. They will be very faint if they are there so trying in a darkened room may help to see them.
This is just to verify that it is only a backlight problem.
If there are images then here’s the relevant troubleshooting section from the SM-T580 service manual that may help.
Also check that the LCD cable systemboard connector pins aren’t damaged or bent etc.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Chris Watson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 360
