주요 콘텐츠로 건너뛰기
The HTC EVO is a Smartphone by HTC powered by a 1-GHz Snapdragon processor and runs the Android operating system.
71 질문 전체 보기
USB port connector and 5 soldering points
There are five soldering points on the board that is connected to the USB port pins. However when I see those ripped off the board, I see some of the soldering points are detached with the port's pin. However, yet when I put a new port on the board, sometimes it works only with 3-4 connections.
But when I put another port on with one missing point (2nd from right), customer says it is not charging the battery even though the light comes and screen shows battery charging indicator. so I would like to know if anyone know about how many and which pin must be connected to charge the battery?
Anyone?
Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
I believe that the EVO 4G uses a standard micro USB connector. The pinout is as follows
Pin Name Description
1 VCC +5 VDC
2 D- Data -
3 D+ Data +
x This pin may be connected to GND for cable detection.
4 GND Ground
Pin 1 is the far left when you look straight on. So pin 1 and pin 5 would be my choice to charge. But that's just my 2 cents....:-) Good Luck
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Thank you so much! so that is why even without 3, or 4 pin, it still showed charging volt and the light came on. That is good to know. Now I wonder why my customer said the battery wasn't getting charged when all pin except 4 (solder point ripped off) was connected.
Pin 4 may be what was needed for the phone to realize that there is cable that is plugged in to charge. Thanks for accepting my answer, good luck to you.
댓글 달기
귀하의 답변을 추가하세요
ifixsmartphone 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,280
