주요 콘텐츠로 건너뛰기
Repair guides and information for portable, battery powered Bluetooth speakers
100 질문 전체 보기
Ion Bluetooth speaker won't stay charged even after 8 hrs
Ion Bluetooth speaker from Walmart won't stay charged even after 8 hours of charging with no use , unplug for a minute and it dies. Will work while plugged in but that's it.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 3개
I Have A Ion Bluetooth Speaker From Costco
When I Charge My Speaker It Stays Charge
I Don't Have Too Charge For Weeks.
I Play My Speaker Everyday And Can Charge My Phone
Conga Master
My Bluetooth speaker will work plug in the wall but I unplug it will not work has to be plugged in all time
@detrickmarshall
What is the make and model number of the speaker?
댓글 달기
답변 2개
선택된 답변
Hi,
Given it works when plugged in but not on the battery only, it appears as though the battery is faulty or has failed and needs to be replaced.
I cannot find a teardown video online that shows how to open the speaker, but here’s a link that may help in finding the correct replacement battery.
According to the link, if you have had the speaker for <90 days from new, then the battery is covered by the manufacturer’s warranty.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thank you, I just came across it myself, just before checking here. Again thank you
댓글 달기
I have to replace my battery. Want to know if the Ion Bluetooth speaker charging system works with lead acid batteries & lithium.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Mine powers on but won’t connect to Bluetooth only radio any suggestions besides replacing the battery which I did but the company sent me the wrong size
you need to download the app and connect to bluetooth thru the app. THEN connect to audio via phone bluetooth
댓글 달기
귀하의 답변을 추가하세요
Chris Marques 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 38
30일 전: 137
전체 시간: 7,602
