New battery not charging. Showing "service recommended".
Hi guys,
So, I replaced the battery on my A1398 Mid-2015 Retina MacBook Pro and now I can’t turn on the laptop on battery. Also, while it does turn on with the power adapter, it doesn’t charge the battery, and if I remove the power adapter, the computer shuts down.
Any ideas?
I remember having a similar issue when replacing the battery on an A1502, but I can’t remember how I solved it lol…
Things I’ve already tried (with no success unfortunately):
- different charger
- SMC and PRAM reset
- Safe Mode
I feel like it’s probably something I’m missing. Something small. But I’m just not sure what else to try. I kinda doubt the battery is damaged in some way, it’s a new battery after all…but also, I have no other idea right now.
What would you recommend?
Screenshots from the menubar and Coconut Battery below.
Also, from System Report.
For what I can tell, the system does see the battery… It just doesn’t wanna charge it, for some reason.
Update (01/06/2022)
I managed to take some pictures of the board. I’m definitely not a specialist, but it doesn’t seem to be anything wrong with the board. Also, I’ve tried the old battery again, and…works like a charm. So I don’t think it’s the board. But I can’t figure out what am I missing, if it’s on the battery side (as it seems to be).
Also, forgot to answer your previous question, but I took some pictures of that too, the connector itself seems ok (for as far as I can tell)…so does the one on the board.
You can see all the pictures below. :)
Looking forward to hearing from you.
Update (01/05/2022)
Aaalright folks.
So the new battery came in today (yeah, it took a lot longer than anticipated) and…yeah, it’s powering the computer up (without the charger plugged in) and charging just fine. So yes, it was the battery indeed.
A few interesting things:
in Catalina, the battery automatically showed up with Condition: Normal. In Monterey (probably Big Sur, as well), it showed as “Service Recommended“
in Monterey, to make the battery show up correctly (Condition: Normal), I had to do a NVRAM/PRAM reset using Alt/Option + Command + P + R + Power Button (from a shutdown state). I thought doing an SMC reset would actually do this trick but nope, resetting SMC didn’t help. Resetting NVRAM/PRAM did. Just though it might be interesting to mention.
Thank you very much @flannelist for your feedback!
좋은 질문 입니까?
