Why won't my gas fireplace light when I turn on the switch? Pilot on.
My gas fireplace has a wall switch to turn it on but it doesn’t work. I see the pilot light burning and the gas valve to the fireplace is on.
좋은 질문입니까?
좋은 질문입니까?
Best left to a professional but you might be able to fix simple things. The pilot light should have a small metal rod or two beside it with the flame heating them up. This is a safety system designed to keep the fireplace from lighting if the pilot light is extinguished. If the rod is too cold the fireplace won’t turn on the gas valve to light. To test where the problem might lie, use a long-nosed butane grill lighter to add additional heat to those metal rods to see if the fireplace will light. Be ready to step back if it lights the fireplace to avoid hairless arms. You may need to hold the flame of the grill lighter on the metal rod for 30-45 seconds (with the switch turned on) to heat it up.
If the fireplace starts then it’s likely 1. the pilot light needs to be turned up a little. check the gas valve on the internet to see how and/or 2. the thin tube feeding gas to the pilot may need cleaning . they commonly get spider webs inside them (if you remove it turn OFF THE GAS and don’t kink the tube reinstalling it.
이 답변이 도움이 되었나요?
As said before, this is something you should leave to a professional, but here is my read on it...
There are actually two systems that generate electrical energy from the pilot light. Both are usually located right next to the pilot burner, on opposite sides of it:
One other thing that many people forget is to also check the actual On-Off switch, as these can go bad. Check it out for continuity, as this may also cause the same symptoms.
이 답변이 도움이 되었나요?
On mine, it ended up being a loose/corroded wire (spade terminal/connector that were plugged together, but not making good contact) on a sensor on the exhaust pipe. Maybe some over-temperature flame sensor or something. It seemed to be normally closed though. So don’t forget to check any lockout circuits you might have (like an open door switch). They generally are all fail safe (normally closed).
If the pilot is on but your gas fireplace won’t light when you flip the switch, a few common issues could be the cause:
If simple fixes (switch replacement, battery check, cleaning) don’t solve it, call a certified fireplace technician for safe diagnosis.
이 답변이 도움이 되었나요?
On the Heat & Glo all you need to do is tap on the gas valve gently with a hammer or rubber mallet. Turn it on so the pilot is lit. Tap on the round flat part of the valve that is facing you, and voila, the burner will light. Not sure why that works. If anyone knows why, please let me know.
이 답변이 도움이 되었나요?
Ha ha ha I tried little tapping method on my gas valve and instantly it turned on. Thank you for your comment. You saved me $400 service call.
지난 24시간: 48
지난 7일: 396
지난 30일: 1,710
전체 시간: 86,003
댓글 1개
my fireplace does the same thing and my husband's answer is to bang on the front of it with his fist
honestly that scares the crap out of me !! I am going to try the answers shown here, if the don't work I will call a professional !!
Thanks for help that doesnt need to involve a fist !!
Kelly Gardner 의
