2019년 3월 출시, 모델 번호 SM-A305FZRFINS로 식별됩니다.
jenniferpinnell1973 @darkangel73
평판: 1
게시일: 2022년 1월 18일
Why is my A30 stuck in a loop.
좋은 질문 입니까?
댓글 4개:
Hello.
Have you tried to force your phone to reboot..?
I think you need to hold the power down for 10 seconds or something.
When its off you need to wait a few seconds and then hold the power button again until it wakes up.
I'm not sure if this is a quick fix hack or is there some longer / better solution
Stephen Gilsenan 의 2022년 1월 18일
I've tried that. Stays stuck in its loop. I've tried the boot menu. Stays stuck... But thank you.
jenniferpinnell1973 의 2022년 1월 18일
Ok.. I did find something that was related to - Samsung Galaxy A30 keeps restarting, Freezing Problem and Closed Unexpectedly | How to Fix? -
if you search that you may find a suitable answer
@eureka is this what you were relating to :https://hrdreset.com/samsung-galaxy-a30-... ?
It is okay to add links into your comment or even to your answer. If iRobot "bites" again let us know :-)
oldturkey03 의 2022년 1월 18일
bill @ruggb
평판: 3.9k
3
could be a bad battery or one with low charge. It may be shutting down after it tests the battery charge and finds it is below the shutoff level.
해당 답변은 도움이 되었습니까?
댓글 1개:
Not the battery, does with full charge. Thank you for your help.
Erick Mathias @erickmathias
게시일: 2023년 3월 13일
Why does my A30 just keep switching on and off to the Samsung?
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 558
Hello.
Stephen Gilsenan 의
Stephen Gilsenan 의
oldturkey03 의
