Can I replace Lead Acid battery with Li-ION?
Hi guys can you hel me? I need to replaces a battery in a battery powered amplifier (samson xp106) It has a 12v 9ah battery and I´m wondering if I can replace it with a Li-Ion battery. Also if the charging method would be the same.
Thanks in advanced
(also excuseme but my device is not listed in this website)
좋은 질문 입니까?
댓글 4개
Can you take a picture of your GEL battery and post it here? 기존 질문에 이미지 추가하기
Andrew S 의
I just add a pic
AriCohelo 의
@aricohelo How does the battery charge currently? Why do you want to replace the current battery with a Li-ion?
Andrew S 의
The reason is the weight.
It has a charger 18v 1,5ah, it came with the amplifier. But I can buy another kind of charger and use it outside the amp I guess
AriCohelo 의
