Dry won't turn on
My dryer no longer turns on.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개:
@cyruca1 what exact model is your dryer? What have you checked? Did this just happen all of a sudden or were there any issues before
의
Have you checked your breaker panel/fuse box?
의
Check the vent hose and check that the pipe through the wall isn't clogged. If it's vented through an outside wall, then it's likely a really short, easy to access pipe that can be easily cleared, if it's clogged. If it's in an interior place, then the pipe unfortunately is long and could have bends in it. There are brushes that attach to a drill. The segments screw together, but duct tape or electrical tape the connections. You do NOT want it to come apart inside the wall.
의
댓글 달기
