HELP! MacBook Pro Shuts Down Unexpectedly During MacOS Reinstallation
Trying to reinstall MacOS using internet recovery after wiping the MBP; and UNEXPECTEDLY, my MBP shutdown in between the reinstallation.
Can it be a hardware issue? (I have already run apple diagnostics on it before and its results were OKAY)
SSD Driver Make model:
Coconut Battery Stats:
좋은 질문 입니까?
댓글 2개
Lets first look at the basics! booting up under an external drive if you need to. Install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 기존 질문에 이미지 추가하기
Make sure your charger is plugged in as well.
Dan 의
Hi, @danj thanks for the answer.
I have tried booting up from usb drive. First it booted up and i erased the ssd with APFS Partition but couldn't install MacOS due to corrupt download file.
But now after downloading fresh macos copy, it also shuts down and restarts during usb boot up. What can be the issue?
Also regarding coconut battery, I've lost the screenshot after erasing the ssd. But i can tell it has 101 charge cycles and 91% battery capacity which fluctuates between 89% to 94% sometimes.
During boot up with usb/ internet recovery, an abrupt noise comes from the fan and then it shuts down and restarts it self after 5 seconds.
Farhan 의
