4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
3272 질문 전체 보기
Screw extractor still too big
I bought the Precision Screw Extractor Set to try to remove a stripped screw for a iPhone 4, but the smallest extractor is still too big for the screw. Any other tips for removing small stripped screws?
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 6
댓글:
Same problem. Purchased the same Precision Extractor Set for the specific purpose of removing a stripped screw and does not work. Any solutions?
의 답변
so guys do you recommend me to buy the Precision Screw Extractor Set..i have iphone 4s with one striped screw and i cant take it out....have you found any way to take out ???
의 답변
Same problem here, I would appreciate a solution...
의 답변
Any idea how to remove worn screw in battery cover in iphone 4? Tried the super glue trick but the screwdriver just doesnt want to glue to the screw. The nail cliper wont work as the screw is hidden in the frame so no way to grab its head. Help please.
의 답변
의견 추가하세요
아이폰 배터리 수리 키트
Only $29.99
Buy Now
아이폰 배터리 수리 키트
Only $29.99
Buy Now
9개의 답변
가장 유용한 답변
My boyfriend extracted the stripped screw that held the battery in place by using a pair of nail clippers as pliers. He gripped the edges of the screw with the head of the clippers (I can't remember if he used a concave or convex one but either should work) and twisted until it came loose, then replaced the battery as shown in this video
http://www.youtube.com/watch?v=KYvjuWg06...
The 4s battery swelled a year and a half after getting his phone, but when he took it to the Apple store the sales rep claimed they couldn't replace it due to a potential explosion and his only option was to buy a replacement phone (of course) for $150.
He ordered an iPhone battery replacement kit from Amazon (http://www.amazon.com/gp/product/B009SJG...) and tried the screwdrivers that came in various repair kits but they were all too big, and also attempted the superglue method but couldn't get the screw to stick. Thankfully he was able to replace the battery after discovering the nail clippers could work as pliers, and nothing exploded (in yo face, Apple store!)
Good luck :)
해당 답변은 도움이 되었습니까?
점수 6
댓글:
I had this same problem with an internal screw when I was trying to replace the front screen. We were able to get it out by gripping the edges of the screw with some nail clippers!!!
의 답변
The fingernail clipper trick worked for me.
의 답변
nail clipper does the trick!
의 답변
The Iphone 6s metal plate has tiny screws and after the first out of 6 stripped, decided to check online and found this and tried the nail clipper method and it works great! you just need to use the clipper to loosen the screw just a bit and use the screwdriver to do the rest.
의 답변
의견 추가하세요
Which screw is stripped? A small slotted screwdriver (flathead screwdriver) can sometimes work. A small screw driver with a tiny dab of superglue on tip, hold to screw perfectly still, let dry, then unscrew. Take old plastic pen, heat till surface melts, press into screw head to make impression of screw head, let it cool-harden again, use as screwdriver to remove screw. Sometimes just a new screwdriver helps, because screwdrivers wear out, and a new one may have just enough bite to get the stripped screw out.
해당 답변은 도움이 되었습니까?
점수 4
댓글:
Thanks - the slotted screw driver worked for me.
의 답변
The slotted driver worked well - however it damaged the tip of the driver.
의 답변
의견 추가하세요
I just had this problem tonight. The screw holding in the battery on an iPhone4 is easily stripped. After trying everything I could think of and searching online for a solution, I ended up breaking out my electric drill and a drill bit slightly larger than the hole in the stripped screw.
I set the drill to turn in the same direction as will unscrew the screw, and carefully placed the bit on the screw -holding very carefully of course- and hit power. At first the bit didn't seem to be doing anything, but as soon as it caught in the screw hole the torque just spun the screw right out.
I replaced the battery and didn't have another screw to put in so for now I've left it out until I can order a replacement. Phone works fine.
If you're frustrated enough to try this yourself, hopefully it works for you as it did for me.
해당 답변은 도움이 되었습니까?
점수 2
댓글:
Thanks Harry, this worked perfectly after the superglue and flathead did not.
의 답변
의견 추가하세요
Personnally, I have been to Canadian Tire to buy a Dremel tool. I used the smallest of the rotative tool to create a space to use a flathead to twist the screw... It worked perfectly !
해당 답변은 도움이 되었습니까?
점수 1
댓글:
The nail clippers worked for me!
의 답변
의견 추가하세요
You can try this but i must warn you to be VERY CAUTIOUS in what you are doing. I used this method and it was successful for me, but then again, it was a small screw. *I am not responsible for any damage done to your phone* :)
Ok, so i took a power drill and used it on the top screw of the EMF protection shield. The screw was stripped so I took the smallest drill bit i could find that would just fit the circumference of the screw. Then, very carefully screw into it, completely making the screw into a bowl. Next, switched directions of the drill, used a little force and went slow....next thing i know the screw is out. You can try this but just be careful and don't break anything. GOOD LUCK! Let me Know if you need anything else.;
해당 답변은 도움이 되었습니까?
점수 1
댓글:
help me!! Ive made it into a bowl,switched directions, but its still not coming out!
의 답변
The screw I was trying to remove was stripped into a perfect little bowl. I used a glass/tile bit and it spun about 6-7 times and then grabbed right on and vwalla!!! My son has a fixed phone, saved his money for something down the road!
BTW - His phone was acting very bazar and with a new battery (amazon) it's working very nicely again.
Don't give up
의 답변
의견 추가하세요
I had two stripped screws on the inner casing (both were the type with washers). Two of the final ten you need to remove before you can pop out the screen. They were in the same location, just on opposite sides, very odd. It took me nearly two hours, and multiple different methods to get them out; including the super glue and melted pen cap. I finally had to use my sisters hemostat clamps (thank god for nurses) to grip the washers and turn them. It took a long while, but after much patience it worked. Im sure you could also use a small set of pliers to achieve the same result. I ended up just leaving those two screws out when I reassembled, and my phone works just fine.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
thanks you so much @donita your response really helped!
의 답변
의견 추가하세요
Same problem. The screw head on one of the screws holding the battery contact was stripped badly and I had no super glue or drill or dremel handy so I decided to use the pentalobe screw driver used for the two screws holding the back plate on. IT WORKED! I guess the points on the pentalobe gave just enough grip to loosen the screw.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
I also had an internal screw that was stripped on an iphone 4. Tried several different things but the one that finally worked for me was using a large rubber band. For those who haven't seen this trick, all you do is take a large rubber band and lay over the screw. It will fill in the negative space where it is stripped. Use the normal phillips heads screw driver and turn it very slow. It worked for me. I had tried for a couple of hours before this and was already very frustrated and had no faith. Am very thankful that it worked. I have no replacement screw and haven't put phone back together yet. Am hoping for as much luck in that it works without a replacement. At least this will help you get the screw out . Good luck
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
After 45 minutes of trying unsuccessfully different techniques, I took a screw driver that had come with an iphone replacement batterie), I lit a candle and heated its tip for no longer than 15 seconds, applied to the screw ( holding the iPad 2 power button bracket) and to my amazement , the screw CAME RIGHT OFF!
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
dyoungnz 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 35
전체 시간: 75,107
