주요 콘텐츠로 건너뛰기
Repair and modification information for the Creality CR-10S Pro, a 3D printer from the CR-10 series released in 2019. This first version was succeeded by the CR-10S Pro V2.
7 질문 전체 보기
Nozle hits the bed
Hello, the nozzle keeps hitting the bed. What can I do?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
when mine did that i checked on you tube and watched videos on it. one thing is have you done an manual bet level? then adjust the screw on the auto bed level sensor. that would be the videos i would watch
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
if the nozzle hits the bed then your z-axis offset is off. you want to go into the settings menu, and then to the bed level option. if while the auto-home part the nozzle hits the bed, you have to options:
A: lower the bed by tightening all of the bed-leveling gears under the bed
B: manually move the z-axis (red circle)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dominykas Jancauskas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 27
전체 시간: 357
